I have had my car for about 13 years. It has always had this vibration. Rotate and balance tires alignment. Still there. It does seem to come and go from time to time.
It didn't bother me too much before because I hadn't done a lot of work on the suspension.
Well now that has changed. I have replaced everything I can think of and I still have the vibration. I will give you a list of what I have done to the car.
Neuspeed sport and koni yellow. I did reuse the old stuff. It looked good to me. New lower BJ(moog), Upper control arms(moog) with ingalls anchor bolt kit.
New strut bearings(the things in the front). I have fairly new tires. 5,000mi. New sway bar ends, Ex front sway bar. Vigor rear sway bar. TL calipers, vigor rotors. New inner and outer tie rods. Rack replaced about 2-3 years ago. Made no diff. I replaced the wheel bearing on the pass side. It was still there. So I went to the JY and got two more hub/bearings. Replaced the passenger side with one from the JY. No help.
I haven't replaced the engine mounts. Do you think this could be it? I have purposely driven around at the same RPM as the highway vibration in 4th gear and I get no vibration.
I am kind of at a loss of things to do. So anybody with any advice?
thanks
Steve
thanks
Steve
