Tire sizes
    Tire sizes
    I have tein s tech springs and i would lik to kno what would b a good tire size on 16s i am goin to get rotas. the drop is about front 2.1 and rear 1.8
    Cali.Dumps.Harder.
      Originally posted by fizzbob7
      205 45 16
      got pics?
      Cali.Dumps.Harder.
        Originally posted by Cb7shot
        got pics?
        nope
          search members rides, just type in the tire size, i'm sure someone has to have it
          Members Ride
            after researching 16" wheels i believe that 205/55/16 would be the best looing size on the 4th gen accords.
            just my $0.02
            -1992 Accord EX H22 234whp 185wtq
            -1993 Accord EX SOLD
            -1995 Accord EX Wagon Daily Driver
            -2012 GMC Canyon V8 4x4
              205/50/16s. enough sidewall on the tires for a comfortable ride, and at the same time, the 50s profile lessen the chance of the tires rubbing with the 2in. drop.
              5.6L V8 32V DOHC
              JDM HERITAGE - US BUILT
                I'd have to agree with Francis on this one. If you're over a 2" drop in the front (which you are) you can get away with less sidewall and run a 205-55. If you had a smaller drop, I'd go with what hondatuner4267 said and get 205/55.
                  205/55/16 is gonna be a bit tall.....fuck, i can't even remember the stock size anyway, so blah
                  i know i ran 205/50/15's because they were close, or 195/60/15, so a 205/55/16 has to be taller, which would make your speedometer read slower than what you are really doing
                    It should be about 1/2" larger in radius than the stock tire. I have a 215/45 on my 17, which is roughly equivalent to that size. My speedometer read 2-3 mph high when I bought the car, and it's still in roughly that margin.
                    The only reason I mentioned that I would run a size like this was in the drop situation. You can cheat the wheel gap a little by running a bigger tire with a less severe drop.
                    But I do agree with you that a 205/50 tire is ideal if you've got a decent drop on the car.
                      205/50/16 to be accurate on your speedo. if you want a better look but it may be too small go 205/45/16.
                      check this site out:
                      http://www.mx5.net/garage/tirecalc.html
                      remember the stock tire size for an EX is 195/60/15 for reference.
                      1cor10:31
                      - 92 LX coupe
                      - 96 EX wagon (sold)
                        Cb7shot, note that the resulting fender well gap is also influenced somewhat by which struts you are going to use. Apparently they don't all have the exact same spring perch location.
                          i gto 18"s, 225/40/R18, it looks good on ym car
                            I can vouch for what Deckeda says. Compare my ride height to that of Owequitit's car. We both have the same springs, but our struts differ. His car is noticeably lower than mine.
                            KYB AGX are known to kill your drop by probably close to 0.3". That is why I went with a larger tire...to "cheat" the wheel gap. However, if I was lower, I could have run a smaller tire and not had to worry about that.
                            That's why I was saying depending on yourself, but a 50 and a 55 series tire is an option.
