So heres a new idea for a swap. N22a2 diesel swap into an accord the n22 has like 250 ftlbs of torque. Appearently its found in accords in japan (or europe). if anyone has info on this engine it would be greatly appreciated because the wikipedia listing is useless. here it is http://en.wikipedia.org/wiki/Honda_N_engine#N22A2
N22a2
N22a2
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.Tags: None
actually its probably not that bad. It cant be worse than a mercedes 190D because that had a 2.5L turbo diesel and the n22 of course is 2.2L
Originally posted by TheNextEpisode View PostThat would be pretty cool.
I can't imagine dealing with Cali smog reqs with it, though.
edit * - Currently, smog inspections are required for all vehicles except diesel powered vehicles, electric, natural gas powered vehicles over 14,000 lbs (city buses), hybrids, motorcycles, trailers, or vehicles 1975 and older.Last edited by gcvphoto; 12-28-2009, 06:05 PM.
Originally posted by gcvphoto View PostThat is because you don't have to. In cali, you do not have to smog diesel engines. I promise you that.
there is about to be a HUGE shakeup for CA diesel smog laws.
it affects the heavy duty/ag industries more than anything but passenger cars/trucks will soon have to be tested.
as to what year the cutoff is and the specs they will be scrutinized under have yet to be solidified.
anyhow.
it would be sick as fuck to have a CB with that kind of low end grunt.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
That's a good point about diesel smog checks. However the part I was referring to was complications with BAR'ing the diesel swap.
As far as the state is concerned, a CB, even with a diesel swap, is due for a smog check every couple years until the swap is validated. That validation might be a hairy process.
Originally posted by TheNextEpisode View PostThat's a good point about diesel smog checks. However the part I was referring to was complications with BAR'ing the diesel swap.
good luck finding parts for it stateside while your at it. pretty certain almost nothing would be readily available.
its a pretty fun idea but one that is likely never to get off the dream/drawing board.
from the limited looking i did, it appears that this motor is in european crv's and accords etc, so it may have similar mounts to the k-series
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
