As the title says... My H22 has been off the road since September 2008.
I plan on getting it running in the next few days, but I know starting a motor that has had that much time to sit can be tricky. I don't want dry pistons to tear up the sleeves! What's the best way to keep this from happening? I've been told to put a bit of oil in the spark plug holes, and pour some over the cams. Then turn it a few times by hand. That makes sense, but I want to double check before I do it... Any specific details would be greatly appreciated!
I know the gas is probably old... hopefully it'll be good enough to get the car running. I'll dump some octane booster in there, and drive it very carefully to the gas station.
Is there anything else I should be concerned about?
The clutch, pressure plate, flywheel, and hydraulics are all brand new. The ECU is a chipped P28, currently running a random basemap (I have a custom tune that requires a new o2 sensor...) The ignition components were all in good working order when the car was taken off the road.
The battery is an Optima Red Top, so I'm HOPING that it can be recharged.
I've started the engine after extended periods of inactivity, but never anything this long. I don't want to do any damage! Please, anyone who knows their stuff... treat me like a noob. I don't mind reading instructions as if I were completely clueless... It's better than missing something that I SHOULD know!
