H22 vss question
    H22 vss question
    I noticed the H22 vss doesn't have the hoses like the f22 and that the sensor plug is different. I reall am lost in what I need to do. Is the H22 vss self lubricated and do I just switch the sensor plugs and cap the 2 hose ines? My swap will remain an auto.
    2013 Honda Fit Sport Alabaster Silver Metallic GE8
    2013 Accord Sport Modern Steel Metallic CR2
    CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
    CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
    GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
    Just use the one from you f22
      Will that work? It would be a simple solution, but im thinking that the h22 tranny came like that for a reason?
        The speed sensor is the same between the H22 and F22
        You can use either.
        Part number is the same too, 78410-sv4-003
        My swap thread
        Main relay proplems?--DIY
          probably got a tranny off a bb6. I got one with the same thing. any how, just loop the lines on the rack. you dont have to lube it with PS fluid like the older trannies. the tranny seems to do it by its self.
          as for the plug, I think I saw the DIY for it to swap plugs out in this area. its easy
          93 Accord LX Sedan (sold)
            You can use either.
            Not the one on mine lol. Its probably becouse its a mp0a auto Thanx for the help. Im probably hagle you some more at the meet this weekend if you go.
            Cool. That sounds like an idea. So I just have to switch the plug. Thanks.
              Mine was the same as what you said on the T2T4 I got with the H22. I just used the one off the F22 but have always wondered if I could have just used the one off the T2T4 to eliminate powersteering
                you mean the mp1a? i have the same exact one if thats the case and mine ended up working just fine. do you know the exact year range your tranny is from? cause just like stated above it is possible you happened to get a bb6 tranny rather then a bb4 and im not sure if they would be the same then.
                  No the tranny is a jdm mpoa.
                    okay you have the non lsd one. its weird cause i just put everything the same way it came off plugged right up. and mine does have the 2 plugs for the hoses as well.
                      Maybe it came off of a bare model prelude or accord without ps
