Engine Harness Difference between CB and CD?
    Hi, I'm currently doing a jdm h22 swap right now and everything is going fine until I got to the wiring part. I'm using a 94-97 guide
    What I want to know is if there are any differences in the wire color because I can't seem to find IAT plug that has green/blue and red/yellow
    or the IAC Valve.
    Thanks
    http://www.cb7tuner.com/vbb/showthread.php?t=161738
    Vouch for: new_beginnings, tommi
    OBD2 or OBD1
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
      See if your local library has AllData.
      Accord Aero-R
        It's an obdI motor and I'm doing it on a 92 accord
          IAT should be
          Green/yellow or greem/white with a red wire
          NEW CB
          new
            Okay Thanks
            The IAT wire was green/ white with red/ yellow.
            These colored wires on the 94/97 guide seems to be different than the cb's
            is there any websites with wire harness colors for the cb?
            I still need to find MAP, EGR and IAC ones...
              Originally posted by benstuh View Post
              Okay Thanks
              Iacv is
              Blue/black and yellow/black
              Egr is
              Green/white or green/yellow,black/white,yellow/white
              the map isnt on on the the engine harness of the cb its on the main Chassis harness
              NEW CB
              new
                I know that the Map isn't on the engine harness but the swap faq said for me to use the h22 map. So then I would use the h22 map sensor or the f22?
                btw i REALLY appreciate you guys helping me out. It's so stressful figuring out this whole wiring thing.
                  Use the obd1 h22 TB
                  NEW CB
                  new
                    okay, so I plugged in all of the sensors but one on the cb harness does not have a spot on the h22.
                    this plug here with yellow/green and green/white
                    where does this go?
                      i vote you start it up and wait for the CEL to tell you which one it is :P
                        haha i wish i could. except the engine is out of the car!
                          That looks alot like the temp sensor plug.
                            It looks like the temp sensor that goes on the front that the h22 don't have.
                            1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
                            Originally posted by keepinitclean
                            I give it 2 weeks before you sell it.
                              Are you just twisting and taping that wiring? You should really solder it and heat shrink it. I just got 10ft of 2mm heat shrink on eBay for like $3, shipped.
