So I swap the neck off my F22 with the sensor to the H22, but do I need to connect the sensor in the T-Stat housing as well??
H22a coolant sensor
There is only 1 ECT sensor that connects to the ECU. This thread isn't referring to it. It is asking about the 2 fan switches (A & B). They do not go to the ECU. They go to the fan control module. There are also 2 temp sensors, 1 for the gauge and the other is the ECU ECT sensor. The gauge sensor doesn't go to the ECU ether. The 2 wire ECT under the distributor is the only one that sends it's signal to the ECU.
The ECT sensor is located in the head. Right beside the temp gauge sensor. Under the distributor.
The 2 coolant temp switches for the rad fans are located in the thermostat housing (switch A) and the water neck (switch B). As far as I know both the H and F series have them. Can you post a picture of the sensor that you are talking about?
