So i just got my car back from the shop, fully built everything. i got the Innovative mounts (grey) series. Now my question is, since they are racing mounts, is it normal for my car to have vibration/shakes because they are so stiff and there is no play in the mounts? This is my first time with aftermarket mounts. Can guy who have aftermarket mounts chime in on this please? thanks!
Question about Innovative mounts.
100% normal
1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Try the OEM rear mount and the front torque mount, but keep the stiff side and transmission mount.
Auto or manual?1993 SE Coupe MRT - 1992 LX Sedan MRT
Hmmm ill try that, will it calm down the vibration a bit? and its a manual. fully build f22aOriginally posted by wildBill83 View PostTry the OEM rear mount and the front torque mount, but keep the stiff side and transmission mount.
Auto or manual?
I WAS gonna go boost, but i changed my mind.
Yes, most of the vibrations you feel are transmitted through the torque mount in front and the rear mount on the firewall.1993 SE Coupe MRT - 1992 LX Sedan MRT
A front mount will make a difference as well. Why did you opt to go without it? Spreading forces is the best way to reduce vibration.1993 SE Coupe MRT - 1992 LX Sedan MRT
No offense, but if you don't need it Honda didn't put it there.
If Honda put it there, then there is a good chance you should keep it.
GraniteCB7, the problem is that the vibration is not left to right but in the direction of the cylinder rotation. A softer OEM rear mount and OEM front torque mount will effectively deaden that while the stiffer side mounts will keep the motor from rocking.1993 SE Coupe MRT - 1992 LX Sedan MRT
