Originally posted by Dutchaccord
Turbo F20 H23 franckenstein BUILD **pic's+vid**
nvm, u were right. h23 is 87mm, and f22 is 85, f23 is 86.
http://www.honda-tech.com/zerothread?id=1232811Last edited by d112crzy; 09-05-2005, 01:14 AM.
HERE YA GO*******
idle only downpipe
tranny test
/\ this vid shows us testing the new tranny one week be4 he blew the engine (busted his tranny bcs of powershifting)
accord 2.3 turbo @ 10 psi
BOOST in 3rd gear
save as
anyone wondering why this thing broke?
No projects at the moment... danm
2k20:
For sale Demon+ tunerview RD2 Make offer brand new in box
thanks man well do that.... shouldent be to hard. I was just wondering if there was a plugged hole that we could use.
Pixx taken, will post up tonight.
The first f20-h23 frank in holland... w00t w00t
2k20:
Headgaskets compared H23 on the left F23 on the right
F23 gasket on H23 head, note the f23 gasketrivvets interfere with the h23 head. Drill out the rivets.
F20 vs H23 cranck sprockets, also swap the backingplates!
F20 block+ H23 headgasket, checking fitment
Here we'r pulling a plug to insert the waterfeed. We ended up using the big plug on the other side of the oil filter. This bcs the H23 waterplug only fitted this hole.
The next thing we found out was t hat the h23 waterpipe doesent fit the F20, so we need to make a hybrid waterpipe out of the 2... Pjotr is going to do this after he reads this ... lol
This pic shows the hole between f23 gasket and the oil return line on the h23's head. Note the small gap wich needs to be filled with liquid gasket. (see next pic)
The F23 gasket+ liquid gasket
Intake cam in place....
Finished view
We still havent got a place to put the knock sensor.....
didnt find a suitable place on the back of the block.
2k20:
Well actually a knock sensor is a good thing. It senses for knocks that come from uneven detonation. If knocking occurs then the ecu is able to sense that and retard the timing to prevent more uneven detonation/knocking. Overall it just gives your engine better timing. It helps your engine to run more efficently
There will be one eventually...
