So I finally got my engine and running. went through complete hell none the less. no compression at first, 3 valves stuck, 2nd gear in tranny was shot, injectors were toast. yeah. was not good swap.
but as i said, here i am so far. i would like to describe my situation and the things so far to help come to a conclusion on what it may be.
Symptoms - Car runs,
idle is high at times, (roughly 1500+ and seems to fix itself even after idle adjust)
bogs down a bit, vtec kicks in and moves quite well. still think it should have more balls.
things that i had to do that had to fix due to broken parts off new engine -
got new injectors (accel 370 cc) most likely the problem and will prolly be changed to normal 310cc stock.
black box (IAB box?) underneath right side of intake manifold for the IAB was damaged, had to use the accord one and im just not sure if its correctly hooked up. just changed things out on the quick run an it seems to run much better.
possible mix up of sensors between the IAT (intake air temp) and i IAB box sensor?
those are the possible things i can say are the problem. im just curious if i should worry about the injectors? they putting out wayy to much fuel to run efficent? i dunno. vacuum hoses are always a pain? help a guy out if ya could. thanks guys.
. good luck!
