alright, i've been asking around here to some individuals guys but we can't seem to figure it out...well, almost... figured more input could help...
so here's the info: i swapped in the jdm H22 into my 92 ex...i'm running a chipped p28, and all the pin locations on the ecu are correct.... solenoid is fine, and the ecu is good (tested it on another swapped cb).... everything is hooked up..... ok, so when i turn on the car.... there's no CEL, i run the codes anyway, NOTHING..... let it warm up, and take it for a drive.... at the point where vtec should engage nothing happens except for the CEL turning on.. i run the codes again... and then it throws the Vtec pressure switch code.... oil is plenty and clean..... filter is good.... so what's the deal? can it be simply that my pressure switch/sensor is bad? i dont know.. someone diagnose this, please!! thanks..
R.I.P.
