O.K so when my car was broken into they cut a whole bunch of wires from the wiring harness behind the dash and ever since then my car hasn't started. So I had it towed to a garage.
The garage has had it for a while and what they have done is wire my fuel pump up to a toggle switch and I believe by doing so they by-passed the main relay and the ecu and pretty much everything. So now I'm wondering if this is safe? I just spoke to someone else and he thinks that I should have just went to a junk yard and wire up a whole new harness.
So now I have a car that starts, but I dont know if it's safe and another problem that is happening is that my blinker lights are not working properly.
Could this be a result of perhaps having everything hooked up to the fuel pump and by-passing the main relay?
I'm awefully confused and I need some advice!
