H22 problems
    1. The auto tensioner shouldnt crap out unless its old or if you have a bad ass valvetrain which sounds like yours is still stock so auto will suffice unless you didnt change it at the previous timing change.
    2. Realign all the timing marks and make sure everything lines up...If that is good then that is one thing to be relieved.
    3. If you feel like a valve was tapping that can cause a stalling or no start if its bad enough. I would do a compression test on all the cylinders to verify that part is good.
      Originally posted by BB6-SH
      maybe time for h23 manual tensioner
      I thought about it but said fuck it when I swapped. Still A-OK for now
      Follow me on IG: @jdm_inspired
      93 'til infinity
        ok... i agree with the timing belt issue. But there is the possibility of some of the valves being bent now because of the knocking noises that were heard and then gone after a while. The auto tensioner is one of the worst nightmares for an H. I don't care if they are brand new from OEM.... they still can go bad at any time. just ask 90Cb7Sleeper.
        expect the worst and hope for the best !!
        Originally posted by Devergote
        A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
          Originally posted by FuncOvrForm
          ok so how would i got about changing this and would a shop be a good option?
          http://preludepower.com/forums/showthread.php?t=229140
            if all else fails the car will be sold without a doubt
            Cali.Dumps.Harder.
              werd.euro
              Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
              -(B-Pillar Bar Originator)-
                i dont wanna say its the valves due to the sound changing. if it were valves the sound would be consisitant?
                Cali.Dumps.Harder.
                  Talked to a honda tech says its not a belt slip er a bent valve he said a sensor went bad wit the symptoms that i have.
                  Cali.Dumps.Harder.
                    Symptoms now
                    Idles low and rough. A slight rattling sound.. I want to say comming from the right side of the engine bay. Slugish in low rpms mid to high rpms or driving on the freeway seems fine.
                    Cali.Dumps.Harder.
                      also no cel's need feedback.
                      Cali.Dumps.Harder.
                        spark plug bent no spark can be created.
                        Cali.Dumps.Harder.
                          Wow I wonder how that happened. Something must have hit it or just installed it wrong. Do you drop it in the tube? That could cause that. Supposed to let it in with the socket to prevent that.
                            pulled it out that like. these plugs have been in for a little over a year...
                            Cali.Dumps.Harder.
                              would replacing this solve everything?
                              Cali.Dumps.Harder.
                                try and we shall see...
