OK i did research and found nothing that really helped. Called around and no one could find anything. So this is my last chance at solving this.
I have an f22a1 and after doing a run with another street tuner when i got home i noticed a lot of white smoke was dumping out the exhaust. I started to get scared cause i figured this was a sign the motor was gone. So i did a compression test and i got between 190-200 across the board So that made me happy. And it does not sound like a wrx. So i then looked at the spark plugs and replaced them. There was oil in one of them so i replaced the gaskets under the valve cover. Still white/greyish blueish smoke. So i then check my oil. Thick not like chocolate milk. Check coolant still good and high.
I then do another compression to check the motor still good across the board. So i then swapped out to my new turbo to see if it was the turbo it wasn't still smoke. So i put the old one back on.
All i can say is i am stumped. I thought it was the head gasket but it is showing no signs. I noticed some oil on the spark plug of cylinder 3. So i am going to replace the gasket under the rocker assembly today. I just have no idea what it could be.
Any ideas would be helpful.
