Is there anyway to disable the "Brake Lamp" indicator with out taking apart the cluster? I believe I heard that you can do something with the black boxes so the light doesn't come on?
Black Boxes - disable the BRAKE lamp failure indicator?
Bump.
LED conversions are cool, but seeing that light all the time is not.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
permanently bypass the BRAKE failure indicator?
veddy simple eh.
it all starts at the brown box in the driver side outer tail light..
cut the white/green wire (or just remove the pin) that went to the brown box, and connect it to Ground(-). you can tap into the other solid black wires that go along with the tail light wiring on that side.
voila!
Sweet mikeOriginally posted by cp[mike] View Postpermanently bypass the BRAKE failure indicator?
veddy simple eh.
voila!
Me and greencb7inkc thank you
wat?
^^Yeah....what he said.
For real mike, thanks man. I know what im doing tomorrow.
Cool...heh heh heh...cool.
It worked...heh heh heh...
Why unplug it? Just LED that shit, son.
