grindage
    grindage
    hmmm, any help here on this?
    when driving normally, 2nd to 3rd is decent and smooth...
    when going hard, 2nd to 3rd....it just makes a loud grinding noise and harsh vibrates the shifter....
    what could this be?
    ..[CB7][STAR]..
    MY MEMBERS RIDE THREAD
    Manual trans - Syncros worn.
    Rebuild or replace unfortunatly. You can try changing the fluid, but it will more than likely only put the problem off a for a little longer.
    My 5.7 LS1 Holden Ute
      hmmmm, anyone wouldnt happen to know how much it is to replace the syncros would they?
      ..[CB7][STAR]..
        Seems to be a common honda problem. Both trannies in my car have done the same thing. My solution is to not shift hard. lol
          I have the same problem, you're not alone.
            i just need to know an estimate of how much it would be to fix this...cause winter is comming...so the 4x4 comes into play....so if i need to i can fix it now...or put it off till spring...
            ..[CB7][STAR]..
              I have the same problem. I have to slow shift from 4 to 5 or it will grind. Has to be the synchies cuz all the other gears shift fine. I am going to see it there is a bearing and seal kit at Honda Im just going to get all that I need for a full rebuild, and replace all the synchies,all the bearings, and reclearance everything. I cant complain I guess. I got 223,000 mile on it. Its probably going to be expensive, but not as expensive as letting it go til you shave a gear or crack the case.
              My inferiority complex isn't as good as yours.
                i guess it is a common problem...... mine does the same thing.
                Usually i just let off it for a second before shifting into third. I am going to look into a new tranny though. rebuilds are too expensive
