Rear Engine mount question...
    Okay i found a Excellent cond. Rear honda mount at the JY, but am wondering, since Im automatic and staying auto for my swap. Could I use this Solid rear mount instead of my vacuum operated one? Would it cause any fitment issues at all if I used the solid vs. vacuum one?
    ^^^Vacuum one currently on car
    ^^^Vacuum on left, Solid on right....they look like they mount up the same.
    ^^engine mount over the solid mount...looks like it'll fit but not sure.
    member's ride thread
    91 Accord SE 176k
    yes you can use it. just remove the vacuum control silonoid from the firewall.
    btw @ the colorful sockets
    93 Accord LX Sedan (sold)
      did it on mine, works just great
        haha, yeah they work GREAT! I'm not *** or anything....Harbor Freight just had a good deal on those and they keep me organized!
        Did you have to worry about the gap in the last pic though? when I put the mount bracket over the mount there's a slight gap between the two....Will that go away once the bolt is tightened up snug?
        ^^that space between...is what I'm worried about.
        91 Accord SE 176k
          That mount will work, not sure why the sleeve is alittle shorter though. Basically, the USDM's came w/ 3 possible mounts: Auto, EX 5spd (the other mount you have, no vacuum, fluid filled), and DX/LX 5spd (mount is all rubber, best for filling/modding w/ poly, construction like other 3 mounts). And there are 2 rear motor mount brackets, tall and short, tall is for auto and EX 5 spd, short is for DX/LX 5 spd. The rear crossmember is set up for both styles of mounts, Auto/EX and DX/LX, pairing the proper mount and bracket is needed.
          For overall simplicity, the DX/LX is the best, that's what I converted to (93 EX 5spd) and it is to modify. That mount you have will work fine aswell, but the DX/LX is the best and simplest design, it's also much smaller, making it easier to change.
            The DX/LX manual mount and bracket conversion can be applied on automatics as well rite....? Tired of vibration, and sloppy shifting outta the F22b...
              Doing the DX/LX swap on an automatic will actually increase vibration over the automatic vacuum controlled mount.
