well i started to install my h22 plenum and spacer and went to start my car and the shit almost went redline when i started it. so i cut it off immediately and came here. i know the tps looks ok on the outside all the wires are hooked up properly but i dont know what it could be
Need Help ASAP
its not throttle is closed and i can open it manually with the lever but its closed fully. i guess im going to start it to see what it does once i try to start againMaple50175 - you're annoying =P
ok you were right i adjusted the throttle and its not trying to redline now....
but i have a damn idle issue now it goes back and forth between 2 and 3 thousand rpms
ok so i went out there and let it run with no filter and covered both holes inside the throttle and it settled down and started idling ok so what does that mean both holes were covered but all the lines are hooked back up the way they were on the f22a6 manifold
slick dont get offended:
dont be a pusssssyyyyyyyyyyyyyyyyy
bypass the coolant hoses
eliminate all coolant hoses going to fitv, iacv
and buy a can of brake clean, and spray the mani (check for leaks)
u dont live in alaska, i could give u a list of things u dont need, but some people here will start to bitch
oh btw
im not running IABS on MY SOHC (flame suit on)
im not offened but how would i bypass them? dont i need like a block off plate for them???
i just want it to idle right damn it. it sounds way more mean though
