I'm plannin on totally deleting the a/c and all the components that it consists of. I know I can get rid of the condensor, accumulator and compressor but what all else is there besides the lines? What size belt would I have to run after taking out the compressor? Also I want to keep the heat, just to put that out there. If anyone has asked or someone's made a DIY How To thread please post a link to the thread. Thanks in advance!
A/c delete
A/c delete
We are all ricers, it just depends what flavor rice you are.
Minitrucker by heart, CB7tuner by coincidence.
My For Sale Thread
Bowling Pin Shift KnobsTags: None
ur going to have constant heat just so u know. um as far as the belt take a string and go around the crank pulley and up and around the alt pulley and then measure it.Originally posted by dbales View PostI'm plannin on totally deleting the a/c and all the components that it consists of. I know I can get rid of the condensor, accumulator and compressor but what all else is there besides the lines? What size belt would I have to run after taking out the compressor? Also I want to keep the heat, just to put that out there. If anyone has asked or someone's made a DIY How To thread please post a link to the thread. Thanks in advance!miss my turbo cb7
Good deal, I didn't think about using a string and its always got heat, so I already knew that. Thanks.Originally posted by quickangel93 View Postur going to have constant heat just so u know. um as far as the belt take a string and go around the crank pulley and up and around the alt pulley and then measure it.
Any more input into this would be greatly appreciated. Wanna get all the advice I can before tearing into it.We are all ricers, it just depends what flavor rice you are.
My For Sale Thread
False, this "always heat" is caused by unadjusted heater valve control wires.Originally posted by quickangel93 View Postsadly yes
You can just go under the hood and push the heater valve completly closed.
Problem solved
Ok, I figured there was a way around it. I've never heard anyone complain about that, so it didn't make sense to me that everyone was just rolling around in the summer with their heat on by default.Originally posted by CB7Man View PostFalse, this "always heat" is caused by unadjusted heater valve control wires.
Problem solvedThere are no black and white suspension answers!!!!!!!!!!!
That's exactly what I was thinking.Originally posted by quaidum View Posti deleted my a/c in my car and my temp control knob still works isn't that what
controls the heater valve to adjust. why would this become unadjusted when
removing a/c
really you have constant heat with the a/c deleteOriginally posted by quickangel93 View Postur going to have constant heat just so u know. um as far as the belt take a string and go around the crank pulley and up and around the alt pulley and then measure it.
