dohc 2.0?
Loud Tapping noise....
If your camshaft really is worn down that means there's fragments of metal throughout the entire engine, in all the bearings in top end and bottom end and the block would need an entire rebuild before being reliable again. You're definitely better off looking for a complete engine swap to start over with.My Member's Ride Thread
Ya thats what i was thinkin...Originally posted by 19dabeast85 View PostIf your camshaft really is worn down that means there's fragments of metal throughout the entire engine, in all the bearings in top end and bottom end and the block would need an entire rebuild before being reliable again. You're definitely better off looking for a complete engine swap to start over with.
Ya the F20a Is 2.0 Dohc non v
. . .93 Ex F2.0A Si. . .
WiredMotorSports
nah, thats a B20.Originally posted by Teddy View Postso is the dohc the prelude 2.0 ? also is it good on mpg ?
__
