I've done a bit of searching, check my manual and Chiltons and can't find the target oil pressure range for our cars. According to my Glowshift gauge and with 5w30 oil, I'm at 100psi cold 30 degree start and down to 15psi heat soaked 55 degrees at idle.
I can't find the correct, factory specs for oil pressure though to compare to. I KNOW 15psi is too low and I will switch to a heavier oil, this thread isn't about that, please post if you actually know what the oil pressure should be.
