is it the same on the h22a an f22..I wana remove the lightweight pully, im tired of the idle problem, i have a h22 pully(small chip) and a f22 pully but are they the same?
crankshaft pully..
http://cb7tuner.com/vbb/showthread.php?t=85320
I have a spare H crank pulley I can measure if someone has a F they can measure. But I believe they are the same.
interesting.. thanksOriginally posted by tommi View Postthey are not the same. h22 has 5 ribs f22 has 4 ribs so the h22 one is wider than the f22 and will hit the frame rail.
it won't hit the frame rail. My H22 has the H pulley and it clears.Originally posted by tommi View Postthey are not the same. h22 has 5 ribs f22 has 4 ribs so the h22 one is wider than the f22 and will hit the frame rail.
You'll need the H pulley if you want PS w/ your H22. Otherwise you'll be shredding belts because its offset by 1 rib, thereby making the belt sit at a weird angle in relation the the PS pulley.
