First off... hello everyone... long time no post.... Over the past few months my car (90 Accord LX 5sp) has been leaking more and more oil. I have replaced the oil pan gasket already and am now wondering if the leaking oil is coming from a plug that is just below the oil filter. I am not certain, if this is the source, but is this a common thing to leak? I was just going to pull it out and use some teflon tape on the threads. Other than this plug, I am not sure where it is all leaking from. I even went and made sure all the bolts weren't loose that hold the oil pan on.... Suggestions?
Leaking oil from...?
Rear Main Seal..and damn long time although this thread is almost 3 months old..lolHenry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
wrong.Originally posted by Accrdkid View PostRear Main Seal..and damn long time although this thread is almost 3 months old..lol
rear main would leak fromt he clutch cover, not below the oil filter. I personally wouldnt teflon tape it but use form-a-gasket or silicone the threads. if you have an oil cooler that always has issues.
Yes the oil pressure switch is a common place to leak from.Originally posted by thewoahna View PostI have replaced the oil pan gasket already and am now wondering if the leaking oil is coming from a plug that is just below the oil filter. I am not certain, if this is the source, but is this a common thing to leak?
As above, clean the oil off and check it a couple of days later.
My 5.7 LS1 Holden Ute
