Hello this is a problem that I've been trying to troubleshoot for some time now, with not much luck. When I drive slow (<10km/h), the car shuffles left and right at the same speed the tires are spinning. I was told one of my discs might be badly warped. As the speed increases a low frequency humming is heard, and the vibration can now be felt in the steering wheel, and even the floor. After a short trip down the road, much heat is coming from the rim bolts. Driving through a puddle sends steam from the front wheels. Driving at highway speed feels like driving with a flat tire, with a lot of clumsy vibration that is especially noticeable in the steering wheel. As the trip continues, the vibration can get better and worse repeatedly over the course of about 10 minutes. Taking a curve at highway speed makes the vibration significantly worse (lub lub lub lub lub), and then not so bad after the curve straightens. After stopping, the front wheels remain too hot to touch for a good amount of time.
Ive tried rotating the tires. I've checked the brake pads, they are still quite thick. I was told it could be the wheel bearings, warped brake rotors, etc. Everything underneath seems nice and tight. There is nothing loose that I can find. I spun the wheel in neutral and couldnt detect a bad bearing.
How can I check the rotors myself, and how hard is it to replace them?
