Gaskets
    Gaskets
    What kind of gaskets should i buy for the intake manifold and exhaust manifold, i don't want to end up wasting money on stuff that degrades quickly
    im not buying the bisi intake manifold gasket either.
    why not the bisi? mine will be here tomorrow.
    COUPE K24
      I don't belive that a gasket can make that kind of power, i don't care he did a dyno run
      nor am i in a position to spend $50 for a small part
      anyways im not debating the bisi gasket i just want suggestions on a good brand to buy
        oem or felpro then
        COUPE K24
          There are other companies that produce phenolic intake manifold gaskets. ALL others are going to be paper.
          Exhaust, go with Felpro or Honda. They are both very durable.
            OEM Honda was my first choice. They worked for 14 years. Only reason I had to replace them was becuase I took my IM off to clean it. And i replaced my exhaust manifold for a tubular header. I used OEM gaskets when everything went back together. I chose the Nippon Leakless, Ishino Gasket was another manufacturer that you can choose from for both of the gaskets.
            MR Thread
            GhostAccord 2.4L Blog
            by Chappy, on Flickr
              I've never had a problem with any of the aftermarket brands for the intake manifold BUT one thing to note is that unlike the super cheap $5 ones, the Beck Arnley and Felpro gasket that are only a a bit more and have the extra rubber o-ring for the coolant passage just like the oem ones. OEM will be best but I think the Becks and Felpro are good alternatives as well.
              For the exhaust, as long as it not that dimpled cheap ones made of paperish material, any of the aftermarket metal ones are ok
