motor not getting any fuel!!
    Ok I did my motor and turbo swap and also did a wire tuck at the same time and my car cranks but doesn't gt any fuel to the fuel pressure regulator or the fuel filter I took off the fuel lines at the tank to see if anything was kinked up but nothing is.
    When I turn the ignition on I don't hear the fuel pump turning on at all.! I don't think its mikne main relay because I have tested it out with my other one. So my fuel pump is not getting any power please help
    http://www.cb7tuner.com/vbb/showthread.php?t=176523
    i am having the same issue.. I can't figure it out. so if you get an answer please let me know.
      Is you main relay getting power? Also, can you get the fuel pump to turn on by wiring power directly to it?
        i don't know about him but me personally i had the relay in and jumped 5 & 7 which is fuel pump check and the pump came on.
          I also did this troubleshooting method when my main relay failed. It works, jump those two pins and see if the pump turns on.
          Not saying your main relay is going bad, just reaffirming that this jumper method works.
          http://www.cb7tuner.com/vbb/showthre...=1#post1823428
          My Custom BB6 Dash Swap Thread
            When I did a head swap on a cd5 the same thing happed. I forgot to reconnect the engine harness ground. It goes on the bottom bolt of the thromstat housing. Check it and make sure you didnt forgit to hook it up.
            Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
            93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
              post pix of the tuck.
                ive checked everything and i still have no pump coming on. I am going to buy another main relay even though i know that isn't the problem. It doesnt seem like im getting power to the relay... When i jump 5&7 my pump comes on. but when the relay is plugged in it doesn't turn on..
                This is annoying, my car is ready to be on the road just have to put the door panels on and its running again. always something!
                  did you fix your issue?
