So yesterday I ended up buying a new VSS, even though I just replaced it back in March, and still my speedometer wasn't working. My questions are: What are some possibilities that could be causing this?
Does the O2 sensor have any correlation with the speedometer? asking cause I swapped out my chipped p28 ECU for a regular H22 ECU to see if I had a faulty ECU, had a check engine light w/ the stock ECU not the p28 (code 41) primary oxygen sensor heater.
My next step towards resolving this issue is replacing the O2 sensor if it's the same thing as the code was throwing. If not I read it could be a chip on the motherboard for the speedometer and the only way to fix it is replace the whole speedometer, is this right?
Thanks in advance.
Thanks in advance.
