alright guys ive had this oil leak for a bit it only happens when the cars running, my oil filter is soaked in it, i put a new filter in and its still soaked. im thinking its the rear main seal. does my oil leak sound like it could be the rear mail seal? any help would be appriecated, thanks.
oil leak need help!
The rear main seal is actually at the right end of the engine behind the flywheel. You might try cleaning the back of the block to make sure, but your problem is most likely the oil pressure switch which is mounted to the back of the block immediately above the oil filter. They fail and leak through the switch so replace it, don't just remove it and put some sealant on the threads hoping that will fix it. Other possibilities include a head gasket or valve cover gasket leak.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
im betting on the oil pressure switch. if it is use a 24mm deep wall socket to get the oem one out. the aftermarket ones are 1'' or 1 1/16''. i bought a beck brand from oreillys and it was a 1 1/16. i had to also invest in the universal socket to the new one in.
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
so im gonna go ahead and order the oil pressure switch i looked at it and its covered in oil so im guessing thats it, im not gonna take it out till i have the new one. ive been looking on rockauto and i found them but theres like diffrent styles and what not. i have a f22a6 so if somone could tell me which one i have that would be great thanks
1992 HONDA ACCORD EX 2.2L 2156cc L4 MFI [F22A6] SOHC : Electrical-Switch & Relay : Oil Pressure Switch Wiki Price
ORIGINAL ENGINE MANAGEMENT Part # 8000 {Click Info Link for Alternate/OEM Part Numbers2524089900, 2524089901, 2524089902, 2524089910, 25240D9700, 25240Y9501, 25240Y9700, 37240P2FA01, 37240PD2003, 37240PR3A01, 37240PT0004, 37240PT0014, 37240PT0023, 5862028310, 5862028320, 8941187550, 94118755, 94312940, GPS128}
For Light (Only 4 Remaining)
CAD$2.37
Add to Cart
BECK/ARNLEY Part # 2011565
Oil Switch W/Light [Wholesaler Closeout -- 30 Day Warranty] (Only 1 Remaining)
CAD$2.84
Add to Cart
BECK/ARNLEY Part # 2010262
WITH LIGHT
CAD$5.36
Add to Cart
STANDARD MOTOR PRODUCTS Part # PS198 {Click Info Link for Alternate/OEM Part Numbers37240P2FA01, 37240PD2003, 37240PD2004, 37240PT0003, 37240PT0014, 37240PT0023, 37240PTO004, 37240PTO013, 37240PTO014} Intermotor
With Light;
CAD$7.90
Add to Cart
ACDELCO Part # E1802 {#12337043}
SWITCH,ENG OIL PRESS 1/8IN X 28 THRD ISO, 3-9 LBS PRESS, W/LIGHT
CAD$11.50
Add to Cart
AIRTEX / WELLS Part # 1S6539 {Click Info Link for Alternate/OEM Part Numbers12337043, 1S6660, 2524009400, 2524089900, 2524089901, 2524089902, 2524089910, 37240P2FA01, 37240PD2003, 37240PD2004, 37240PT0003, 37240PT0004, 37240PT0013, 37240PT0014, 37240PT0023, 5862028310, 5862028320, 88924456, 8941187550, 8943129400, 94118755, 94312940}
w/Light
* Non-stock item--shipping delayed up to 2 business days
CAD$4.01
Add to Cart
