I have an issue
My car has a solid CEL light, it cranks all eletrical systems work, interior lights,parking lights,tailights,headlights,radio,heat,a/c etc.
I replaced fuse box, changed the main relay with a working one, swapped 2 working ecus.
Before that my interior light fuse popped 2x but hasnt popped since the car died on friday.
here is whats been done electrically
1. Alarm installed which has been ruled out
2. HIDS which has also been ruled out
3. Radio and speakers installed which have been ruled out.
^^^ none of this changed the problem stayed the same^^^
When key is inserted CEL stays lit and the battery light doesnt come on at all
trior to that my speedo and rpm gauge would die while driving and no CEL would be on ata all I would tap the cluster and it would work fine after that
