I had adjusted mine to trick a P13 into thinking it had a ELD when I had a H22A in my car. Now I have a F20A5 with its PT5 ECU (which is what the sensor was originally for). My car idles a bit rough some times, and I'm guessing this is the culprit, which is why I would like it adjusted how it should be. So does anyone know the correct procedure for adjusting this?
All I can find on the interwebs is that it throws code 11 when failure occurs. That's all I can find on the subject.
