hey can anyone post up pics.. of where you have relocated your fuse box? maybe pics on how you did it... because i dont like where mine is at.. and am a bit confused on how to mount it anywhere else..
Fuse Box Re-Location
I put mine under the passenger seat. I still need to make a couple brackets to secure it.
Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
I will be getting an SE dash with an airbag, removing the bag and putting the firebox uunder that panel for easy access.
Eye Level Media - Commercial & Automotive Photography: www.EyeLevelSTL.comOriginally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Tracie.. thats ecatly where mine is lol i ran out of time to get mine finished.. and drew idkthat isnt the same fuse box.. we would have to do some cutting.. which is cool because i already cut the back outa mine...
and the one on the floor under passenger seat sounds good.. but if a fuse blows.. u gotta pull the seat out
I just finished doing mine. I removed the A/C condenser unit and moved my blower unit over to the left. Then I mounted the fuse box on the right hand side behind my glove box. Worked out well as I only had to make a new ground spot and lengthen my starter wire. The ground was attached to that lonely bolt you see and some of the noise dampener material was cut so I still get air to blow to the window vent properly. (only pic I have, taken during the work).
