Guys, I have done some searching and found muddy water on this subject. I traced the wires from my compressor clutch to the relays on the front quarter panel behind the drivers headlight. I cannot get my compressor clutch to engage, i cleaned the contacts and swapped relays and still nothing. Is there another way to diagnose the clutch or is it a loss? If it is a loss does anyone know the part number? Also is there an easier way to get at it without removing the P/S pump and alternator? I already tried jumping the relay and pulling a vacuum to check for leaks then adding enough freon to trip the relay. I'm just smacking my head into the wall, would it be even worth it to repair the clutch or just get a whole other A/C compressor? Am I missing something? Grrr, not looking to drop $$ into A/C parts just yet but it is so damn hot out.
Maybe I'll go to a junk yard and see if I can replace my mangled front clip while I'm at it.
