So as the title states I have an oil leak. It's been leaking for a while now and it's gotten worse after I replaced the valve cover gasket, and the upper and lower spark plug tube seals. I have a really good feeling it's at least leaking from the oil pressure sensor which I have a new one I just need a big enough wrench to take it off. It is coming from the back side of the engine. I just changed my oil today but can not exactly pin point where it is coming from where else could it be leaking from on the back side?
Oil leak could use pointers
Got a general area? Like back side of motor drivers side near the last cylinder or back side of motor passenger side near transmission?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
You can try snugging up bolts. do 1/4 turn on em, and clean the area where the leak is. carb and choke cleaner works well, as does brake clean for the spaces that are hard to just wipe off.
Make sure to check the PCV valve as well. Excessive blow-by from worn rings will cause more crankcase pressure, and with a bad PCV valve it could be venting poorly and the pressure is blowing oil past the gasket.
Go to the parts store and buy the dye, and use a blacklight to find it.
If you are not familiar with the process, google it. Its easy.
Step one, add dye to oil.
Step two, drive car
Step three, shine blacklight around looking for reflective dye showing oil leak
Step four, fix leakOriginally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by toycar View PostGo to the parts store and buy the dye, and use a blacklight to find it.
Step two, drive car
Step four, fix leak
Get under your car, Look behind your crank pulley, there is a weep hole at the bottom of the timing cover where oil drains from when your cam and crank seals are leaking.
