Im looking into a vacuum leak. I have a new intake mani gasket im gona put on and all my lines are new.
fuel issue
Went to turn it on today.
Car cranked and took about 5 tries of about 4 seconds each try to turn on. After it turns on, it bogged like crazy!!
Revved it to 3k and it was good until i let go of the throttle. It shut off. Checked fuel, had fuel. Checked spark had it. And switched out my fpr. It turned on but was running lean.
Drove to school and voila code 43
Im gona get a new fpr soon and i think im gona have to switch my fuel pump.
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
Still sounds like an ignition issue, I don't see the fuel as a problem unless it is in the fuel mix (too rich or too lean) you obviously have fuel and spark present so all that is left to figure out is timing and compression.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
