hey fellas, So im am getting this squeak everytime i turn the wheel on the passenger side. I used to have a torn boot on the steering rack on that side that i replaced about 3 days ago. the boot has been torn for idk how long. i did not really inspect the tie rod ends but the wheels have no play. do i need to shoot some silicone spray into the rack boot or brake clean?
squeak on passenger side
Dude (Ryandavis33) sounds like your having a few probs with your car lately sounds like mine when I first aquired it. On to my point which I'm guessing is the same I replaced both boots and a mount on my rack, I cleaned the rods with some brake cleaner then put it all back together. I wouldn't be supprised if I'm in due for a new rack but mine makes a sort of swish noise as I go side to side it's pretty bad in the morning after start up you can hear it well but after driving I can't hear it at all, no jerks in the wheel and I'm losing just a little fluid at a time because I have a leaking ( speed sensor hose , its the middle one just to lazy to fix it) I wouldn't be supprised if un matinanced racks go bad it's not something a lot of people think about every day and then they are supprised when it goes out like my friend with a 96 ford escort just lost his after his pump was the loudest thing running and now when you look at it it physically looks bent a bit he tells me its the hardest thing to turn ..
Anyways here is my 2 centsLast edited by schierholz; 11-19-2012, 01:27 AM.
Missing MyOriginally posted by evil_demon_01Do it once, do it right.
Saving a dollar is not worth risking a life.
White -91 LX Sedan - leather converted
Mulberry 91 EX Sedan
The project 92
Originally posted by schierholz View PostDude (Ryandavis33) sounds like your having a few probs with your car lately sounds like mine when I first aquired it. On to my point which I'm guessing is the same I replaced both boots and a mount on my rack, I cleaned the rods with some brake cleaner then put it all back together. I wouldn't be supprised if I'm in due for a new rack but mine makes a sort of swish noise as I go side to side it's pretty bad in the morning after start up you can hear it well but after driving I can't hear it at all, no jerks in the wheel and I'm losing just a little fluid at a time because I have a leaking ( speed sensor hose , its the middle one just to lazy to fix it) I wouldn't be supprised if un matinanced racks go bad it's not something a lot of people think about every day and then they are supprised when it goes out like my friend with a 96 ford escort just lost his after his pump was the loudest thing running.
yea i am having some problems. im telling you shit seems to go wrong before a roadtrip that you have been planning for quite some time.
Im not losing any ps fluid and the boot i replaced had a very small rip in it. i cant pin point where the squeak is comming from but i guess i will just let it go for now since there is no play in the wheel and it only does it when its cold.
i just went outside with a flash light and poked around. i went to inspect the pump and lines and i now see that my trans mount is all f**ked up.
that explains the harsh shift into drive or reverse. i just hope i can make this trip in 3 days and i will fix everything when i get back.
I need a f**king vacation!!!!
Like Tippey said, replace the inner tie rod ends. Tie rods have an inner and outer pair. There is a ball and socket joint on the inner tie rod that is protected by that boot.
Also did you re-attach the air circulation hose on the boot you replaced?1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Yes. The repair was successful. I think its ball joints. Im replaceing the o2 today so i will give it a good lookOriginally posted by wildBill83 View PostLike Tippey said, replace the inner tie rod ends. Tie rods have an inner and outer pair. There is a ball and socket joint on the inner tie rod that is protected by that boot.
