So I should get my valves and guides today. Thanks wes. I should get the head back from the shop friday. So this weekend I plan to change the head/intake and cam.
I have h23 intake, a6 cam and springs, redone head new bronze valve guides, polished the intake and exhaust ports(just shined them up nothing fancy) OS valves, supertech seals.
Parts I have. Felpro headgasket, ARP head studs, Bisi intake gasket, New exhaust manifold gasket, new fuel injector seals, and plenum spacer gaskets. New water neck gasket(the thing in the front that the upper hose attaches to, new ecu, wire, sodering gun, timing belt kit, water pump, coolant, some new hoses( I just replaced most about a month ago).factory service manual. camshaft seal.
I have already swapped the a4 manifold.
This will be sort of temoporary until I get the cam and springs and rebuild the bottom end.
This will be my first attempt at this.
Is there anything I am missing?
Thanks
steve
Thanks
steve
