here's a pic of my radiator neck:
I emptied this radiator and filled it with water like 10 times in order to clean it up before paying money, hoping to use an anti-freeze in a clean radiator and thus I have some questions:
1- how do I clean the radiator ?!
2- how can flush/clean the cooling system total volume, without using the 19mm draining plug !?
3- I am told not to straighten the radiator fins, is that true ?!
4- what about straightening the fins of the panel that looks like the radiator and is located in front of the radiator .. can I do that ?!
5- can I remove this panel without removing the radiator ?! I mean by unscrewing the grill and the upper metallic bar above it, the one attached to the latch/lock
( this is not my car)
I'd rather save $$ for new radiator if it needs to be replaced in the future. As for now, fill the cooling system with pre-mix or fill with 50/50 with distilled water.
