broke a bolt for the power steering ajustment
    So I was trying to quit a squeek going on from the power steering belt, I guess there was pressure wrong and the bolt to the support (black part) snaped I want to know if I can drill that out and re tap and die it?
    Originally posted by evil_demon_01
    Do it once, do it right.
    Saving a dollar is not worth risking a life.
    Missing My
    White -91 LX Sedan - leather converted
    Mulberry 91 EX Sedan
    The project 92
    before you do any of that shit, post up a picture of the problem.
    Usually you can drill a tiny little hole inside the snapped bolt and then use an extracting tool to remove the broken bolt. Im pretty sure I just saw a master tech do this about 2 weeks ago to a crank bolt.
      this should help right now I managed to keep it together
      Missing My
      The project 92
        The whole mounting bracket should come out of the engine bay for proper extraction of the broke bolt.
        A&P-IA
          Thrilling. mabe it would be more up my alley to replace the whole peice. question is can with the power steering the alt the compressor off can it come out reasonably easy without pulling the engine?
          Missing My
          The project 92
            You should take the little bracket off and see if you can get a drill down in there. If you can drill down the center of the bolt you can use an extractor to remove it. Maybe you can try removing the radiator for more room.
            BTW, the bolt broke because that isn't the tension adjustment bolt. That is the bracket mounting bolt.
              I don't think it'll be all that hard to remove the mounting bracket. You should be able to see those bolts holding the bracket onto the block once you remove PS pump and ALT. Note which bolt was installed on which hole as they are different in length, IIRC.
              Mount for A/C compressor is separate from above two units, IIRC.
              Removal of the broken bolt should be an easy job with an "EZ-out".
              Good luck
              A&P-IA
                alright I will go get a new set of drill bits and barrow my friends easy out one way or another I think I should be able to save it worst case is to replace the bracket all together
                Missing My
                The project 92
