Okay guys so i swapped from my delta 272 cam back to stock and did a valve adjustment. I left the balance shaft belt off. Now i have a miss in the engine and its very rough to start and when the engine is under a load (accelerating) it sounds like the valves are chattering but they are within spec and they are quiet when at idle and reving. only under acceleration do i get the noise. Help!!! could the timing belt be loose or off a tooth??
f22a4 cam swap help
f22a4 cam swap help
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..Tags: None
Originally posted by motobmx105 View PostCould the timing belt be loose or off a tooth??
Sounds like the issue, Pinking on acceleration and rough running.
Check the timing.
My 5.7 LS1 Holden Ute
Check the timing.
okay i double checked my valves they are all in spec. but will the engine run if the cam gear is one tooth off?? i have a feeling that might be it... the arrow on the cam gear is pointing straight up TDC on #1 cyl. and the dizzy is pointing a little below the #1 terminal on the distributor..
Originally posted by vh22accord View PostYour cam timing is out. It will run as far as 2 teeth out of time any further and you will bend valves. I would not drive it though you could also burn valves depending on how far out of time it is.
So is it recommended that you adjust the valves after you swap a cam? I put an A6 in mine and didn't adjust the valves.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
