Its a 92 wagon. When the vehicle is idle the temp will slowly rise well above normal.
However , if it's at idle and I press the gas pedal the temp will immediately shoot back down. As if it isn't pumping water without the rpm's being higher.
This is an obvious problem if I plan to stop at traffic lights.
Fan works fine , drives fine , coolent is full.
somthing to do with the relation between when the pump is supposed to turn on and whatever is supposed to tell it to turn on....
