I've been doing some reading, and it seems that my automatic transmission is supposed to require the break pedal to be depressed before the engine will start, and the gear shifter should be locked in park when the ignition is off, unless the key is inserted into the shift locker.
Neither currently work, and while it isn't the end of the world it is something I'd like to fix to continue my factory restoration. Any thoughts? Can't find anything else posted on the forums.
