I just came back from the alignment shop and they said I had uneven caster angles in the front end.
This my DD, so suspension is bone stock, brand new UCAs and lower BJs. I had the Alignment done about 3 months ago, so everything is still in spec, Camber is .1* on both sides, Total toe is 5/32"
My LF Caster is 1.8* and my RF is .4*, both positive.
How do I make my RF match the LF? or should it be the other way around?
Right now, my car pulls to the right pretty noticeably. So I'm thinking the right radius rod needs to be adjusted?
Now, to make it match the LF, would I have to add or remove washers from the Pass. Radius Rod?
Alignment sheet attached:
to about 7° (might be near 7°, say 6.5°?) resulted in the end of the steering arm lowering by 7mm. To obtain this 7mm number I measured the relative locations of the upper and lower ball joints and that of the tie-rod end, and plotted them (side view) in a diagrammatic drawing in CorelDraw, from which I could measure the affects on tie-rod-end height of any changes in caster angle. It was necessary to estimate as best as I could the locations of the centres of the 'balls' in the ball joints and tie-rod end (since you can't actually see the 'balls'), but for practical purposes this is near enough.
