So my cel came on while getting on the freeway. The car lurched a bit then continued to drive normal. I get to work and go to check codes but the cel just stays lit. It still runs normal other than the fact that it will no longer downshift if I floor it. Did I just fry my ecu? Searching says so but if the ecu is fried how is it still running?
Cel on but no codes
It could be. It could also be that you did not jump the service connector corretly. Just try that a couple times before replacing your ECU.sold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
If the connector is jumped correctly, there are no codes displayed (no flashing), and the CEL stays on, it indicates that the ECM is in limp-home mode.
I don't think I have an ECM for an F22A4 with manual trans.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
The car I'm talking about here is my other CB that is auto. If I put it in neutral I can rev it to rev limiter but in d4 it only goes to 3500. If I manually shift it it drives like normalOriginally posted by fleetw00d View PostIf the connector is jumped correctly, there are no codes displayed (no flashing), and the CEL stays on, it indicates that the ECM is in limp-home mode.
LX or EX? What is the part number on your ECM?Originally posted by RyanD View PostThe car I'm talking about here is my other CB that is auto. If I put it in neutral I can rev it to rev limiter but in d4 it only goes to 3500. If I manually shift it it drives like normal90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
