Sorry for the long post, but wanted to include as much info as possible.
Car is 1993 Honda Accord SE--fully stock, original engine and transmission. 333+/- miles
Symptoms:
*D4 light is not on. All other lights on the display are working
*Sometimes will not go in reverse immediately. If I pull forward slightly, and then put it in reverse, it will then work. More often than not, it will go in reverse immediately
*It hesitates from a stop and pretty much just sits there and barely moves. After about 2-3 seconds, it accelerates normally and accelerates fine when going at a higher speed.
*Noticed oil under distributor, but there was no oil in distributor cap but there was some on spark plug wires and plugs themselves
*Drives smooth for about 10 minutes and then it kind of feels like it “shifts down” and then starts to feel like it's missing. It does that for the rest of the drive and is worse between50-70mph. Car runs fine at an idle—no roughness at all.
*Check engine light came on. If reading codes correctly, it's codes 20, electric load distributor and 43, fuel supply system. The only other light that flashes is the ABS light. No flashing for the TCU, but not sure if the D4 light being off is symptomatic or if it's just a burnt LED.
What I've done:
*Replaced ELD from another 93 SE as well as ECM/TCU (donor car has 285K miles) Donor was purchased as a parts car and towed it home, so no idea how it drove on the highway. Was running when we bought it.
*changed out spark plugs
*had whole distributor assembly changed at the dealer
*replaced 02 sensor, and put on whole new exhaust (old one was rusted out with holes)
*bottle of fuel injector tx in 1 gas tank (have filled up 3-4X since then)
*new fuel filter
*transmission flush with Honda ATF
*clean EGR valve
Results:
*CEL is no longer on
*only code 20 (or 2?) is flashing (video link is here :http://s21.photobucket.com/user/Spac...9ikgi.mp4.html
*no more oil under distributor
*car no longer sounds like a Harley
Nothing else has changed. Any ideas on where to go from here?
Symptoms:
What I've done:
*new fuel filter
*clean EGR valve
Results:
