Hi there,
I replaced the tires in June. The mechanic replaced the front lower ball joints and the passenger Upper Control Arm and the power steering rack ( it was leaking badly). And the front brakes
I took my car for a road trip and on the way back I noticed the power steering was pulling to the left. I also noticed that around 60 m/hr the power steering started to vibrate ( Around that speed only)
The driver side tire(inner side) has way more wear than the passenger side tire ( inner side).
I also noticed the front bushing which I replaced , were a bit loose ( there was space between the bushings when I lifted the car.
Rear tires as new as I got them .
Is there anything I can do before taking it to a Tire/alignment specialist?
Cheers
Cheers
