TCU S light blinking no 4th Gear
    Good Afternoon,
    Monday my CB9 decided it wanted to give me trouble. I went to leave work to go to another building and while starting the car up I noticed the S light was blinking and being in D4 I had slow acceleration. I've been manually been shifting between 2nd and 4th, but it doesn't matter if I'm in 4th I only get 4th gear only and no OD. Before this all happened I noticed on the highway at 75mph that the RPMs would flutter between 3000/3100 to 3500 on a straight road. Like it was switching between OD and 4th? Now when I drive on the highway with the S light blinking it's a steady 3500 RPMs. I'm not sure what to do, here are the things I have tried.
    Reset TCU - Problem comes back after a few hours of driving
    checked TCU - Board looks clean no burnt spots
    checked/cleaned solenoids - click and looked clean to begin with
    Here's the tcu codes I get: 1 2 7 8 14 ( I think maybe 4 or 5, can't remember)
    Researching on other websites I have found to try and switch the ECU and TCU out, but I'm doubting that's my situation. I'm going to later try the ECU I have a extra PT6 for my Oddy build.
    For Sale Thread CLICK HERE!
    1991 CB9 EX Wagon
    1990 CB7 EX Sedan
    1997 RA1 LX Wagon
    CB7Tuner Discord CLICK ME! -- http://www.cb7tuner.com/vbb/showthre...02#post3285402
    The ECU has nothing to do with how the transmission is acting. It sounds like your issue is the TCU. I know that you said it doesn't look burnt, but I thought the same thing when I had this same issue. I took the TCU apart and looked at every tiny piece. It could be a burn, it could be a crack in the solder, or it could even be just a wet spot under a capacitor. Either way, it can be extremely hard to find the exact issue on the TCU (I spent 3-4 hours staring at mine to find the issue between multiple times looking at it). Eventually, I found two leaky capacitors and you could barely even tell there was an issue.
    Do yourself a favor. Find someone with a working auto TCU (no issues driving the car). Swap this TCU into yours to see if the issue goes away. If so, then replace your TCU.
      I hope I can find someone with the same accord, all my buddies have 5 speeds that I know that have CBs. I'm going to take a look in my garage and see if I can't find my old TCU unit from my other CB. I switched to a 5 speed with that car and I'm not sure where I put the TCU. I hope it's nothing major.
      1991 CB9 EX Wagon
      1990 CB7 EX Sedan
      1997 RA1 LX Wagon
        Fixed it, was the TCU unit. I did try the ECU before you replied earlier so just in case any one asks the ECU didn't help anything obviously, and like oni said. Now when I went to the yard I pulled a 90/91 TCU and 92/93 TCU. My CB9 is a in between of a 91/92 since it was the first year it came out. I don't know why but my 91 has manual seat belts, has an airbag and came with a f22a6. All the other regular CBs of USDM coupe and sedan have auto seat belts, no air bag and have F22a1s or a4s (as I have seen). I don't know why they made the 91 CB9 this way, but it's just a little odd in my opinion.
        My CB9 is a 91 and it has the sports mode button. When I put the 92 TCU in the CB9 it worked but the sports mode button didn't. The sports mode stayed on the whole time while driving. When I switched to the 90/91 TCU it fixed the sports mode button where it would function properly. The 92 TCU worked but I didn't want that sports mode light on my dash on constantly, I'm picky about those things. Hope this helps someone if they come across this thread.
        1991 CB9 EX Wagon
        1990 CB7 EX Sedan
        1997 RA1 LX Wagon
          Earlier this year I had two TCMs repaired by "mandigital" on ebay. You ship him your TCM, he repairs it and ships it back. Quick service (repaired and shipped within a day). Lifetime warranty. $75; more expensive than fixing it yourself (if you're handy with that sort of thing) or some used ones (no guarantee to work or last), but a heck of a lot cheaper than new ($600+) from Honda even if they were available. Might want to have the bad one repaired as a back up (or put it back in and keep the one in the car as a backup).
