New Trick I Used For O2 Sensor Replacement
    Today, I had the luxury of replacing the what looked like a 17-year-old oxygen sensor which seemed to be rust welded to the bung - uhhhhhh.
    Well, after hitting it with some penetrating juice (all I had was WD-40 in my personal garage), I let it sit for five minutes, and then I wiped the residual off with a shop towel. Of course, the thing didn't budge upon initial attempt to remove it. Before I became fully frustrated ending up with rounded edges on the old sensor, I decided to think like an engineer.
    The problem, I didn't want any rounded off edges on the O2.
    My solution, I took a 0.5" x 3.0" piece of 80 grit sand paper, wrapped the coarse portion around the hex nut portion of the O2 sensor, and then put a 7/8 wrench over the sand paper. 15 seconds later, after some applied muscle to the wrench, .
    I know. I know. Yes, they make O2 sensor tools, but this worked and was a lot cheaper.
    Peace.
    The Lord watches over me!
    "...they did the bowties, I did the ascots, as much as I have, I'm still reppin' the have nots..."
    - So Raspy
    Necessity is the mother of invention. For as many cars as I've owned/serviced, I bought a socket.
    90 LX 4dr 5 spd 389,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
    07 Element EX AWD 193,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
    07 Element EX AWD AT (2) 89,000 - MRT: www.cb7tuner.com/vbb/showthread.php?t=211920
    LOTS of CB7 parts - ENTIRE COLLECTION - FREE
    Come and get it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
      I'm pretty sure I'll pick one up as an addition to the tool box and the collection.
      I guess I was ultimately posting this for someone in a pinch.
      - So Raspy
        you could also use a medium sized 8" vise grip and hit it with a hammer. That usually never fails when I have to resort to that tool, as long as you get it clamped down tight enough onto the nut or whatever it is you're removing.
          #noted. Thanks, K.
          - So Raspy
