Alright, I give up. I'm not letting this go on any longer! It's a....it's a...*sniff*...OIL LEAK!!!
Ok, so it's not that bad. Usually I'll end up putting in an extra quart of oil between oil changes (every 3k miles), but I'm getting tired of this. My driveway has enough oil spots to kill 10 people. Here's what I've determined so far:
At first glance, it appears to be the drain plug. Upon closer examination, it was, in fact, the main cause of the problem...at first. Now the oil is leaking from higher up somewhere, though I still can't pinpoint exactly where.
Another hint here, and this one is REALLY irritating during the winter. When my heater gets fully warmed up and I come to a stop at a stop sign, I'll begin to smell something similar to burnt rubber, but there will be no smoke. It's quite nausiating. When I get moving again, the smell goes away.
To me, the above comment says that oil is leaking onto the heater coil or something of that nature.
Quite honestly though, I'm stumped. I was thinking that maybe the oil pan gasket needed to be replaced, but I've never done this before. Even if it's not the problem, I still wanna do it. As far as I can tell, It's never been replaced. How difficult is this?
So what do you guys think? Oh, and thanks in advanced!
