will EX flex pipe fit?
    will an EX flex pipe swap in place of an LX flexpipe or is it dofferent length?
    will O2 censor be a bitch?
    -sean
    Members ride 15.927 @ 86.76 (f22a1)
    Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
    Arcadia Green Crew #10
    It'll fit just fine, although you'll need to relocate the o2 censor. It's not a bitch to add longer wire so it can reach it's new spot.
      If I'm thinking about this right...the EX DP has the O2 sensor on it, while the LX DP doesn't, with the O2 sensor on the top part.
      If you're using the top part of the LX exhaust manifold, I wouldn't touch your O2 sensor, and just plug the hole for the O2 sensor in the DP. However, if you're doing some sort of hybrid manifold/header/downpipe/ninjapirate thing, I'd relocate it to the DP and lengthen the wires.
