I have removed my tranny and installed a new one. Now I am putting my axles back in. The manual says replace the set rings on the axles. Is that really necessary. These axles are only 2 to 3 years old. I personally don't see a good reason to replace them but figured i would ask. I also want to ask do I put grease on all the axle splines, including the intermediate shaft?
When installing new tranny, do i need to replace set rings on axles
No you do not need to. Unless your axle keeps popping out.~Nick~
No thats fine, I put a small amount of grease, just to keep the set ring in place and make it easier to slide in. But I have also done no grease as well, and neither results varied.Originally posted by zedjr10 View Post
what about putting grease on all the splines including the intermediate shaft and will high temp grease work or do i need to use another type grease?~Nick~
the splined tip of the axle ultimately runs inside of the oil-lubricated transmission. a little bit to pre-lube it is good but ultimately you dont technically need to grease anything that gets inserted beyond the axle seal (the rubber ring mounted to the transmission). Lubing the intermediate shaft is a good idea though.
